Can WinSCP create an automatic copy/synchronization of 1 website dir to another website direct
Can WinSCP create an automatic copy/synchronization of 1 website directory to another website directory or something of similar?
I try to explane what's i need
Example I have:
www.example1.org/original-folder
C:\copy-of-original-folder
www.example2.org/copy-of-original-folder
In reality, the word "synchronization" that I used is also wrong, what I would like is to get a copy of a web folder in another web folder, but I don't care if it works in reverse, I just need one direction.
Basically it is a copy and paste, my problem is that
1) The files and subfolders are many and very large (110gb)
2) I would like that when I add (with wordpress) files or folders in www.example1.org/original-folder, these new files and folders are also copied to www.example2.org/copy-of-original-folder
Is it possible to create a procedure that does this automatically?
^__^
reggio
Example I have:
^__^
reggio
