Exclude folder when downloading
Idonthaveone
I am taking over some work that was done by someone and I need to make some adjustments. However, I am not really good with PowerShell..any help is appreciated.
Add-Type -Path "C:\Windows\System32\WindowsPowerShell\v1.0\Modules\Winscp\WinSCPnet.dll"
#PassPhrase
$Password = ConvertTo-SecureString 'XXXX' -AsPlainText -Force
    HostName = "XXXXX"
    UserName = "XXXX"
    Password = "XXXX"
    PortNumber = 11111
    SshHostKeyFingerprint = "XXXX"
    SshPrivateKeyPath = "C:\key\PrivateKey-UAT01.ppk"
    PrivateKeyPassphrase = "XXX"
$session.SessionLogPath = "C:\logs\winscpprod_pull.log"
# Connect
#Download files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
$transferOptions.ResumeSupport.State =
    [WinSCP.TransferResumeSupportState]::Off
#VAR
$Source1 = "/OUTPUT/"
$Source2 = "/OUTPUT/1/"
$Source3 = "/OUTPUT/2/"
$Source4 = "/OUTPUT/3/"
$Source5 = "/OUTPUT/4/"
$Destination1 = "C:\Bla\1\"
$Destination2 = "C:\Bla\2\"
$Destination3 = "C:\Bla\3\"
$Destination4 = "C:\Bla\4\"
$Destination4 = "C:\Bla\5\"
The script has to copy files from the sftp server to a folder locally. However, it should do this only copying the files in the specific folder and exclude any subfolder of each given source location.
$session.GetFiles(
    $Source1 -filemask= /OUTPUT/1;/OUTPUT/2/" , $Destination1, $False, $transferOptions)
After reading some documentation this is how far I got. However, this doesn't work...I am probably doing something wrong..just don't know what.
