[SOLVED] batch file to open multiple txt files within WinSCP ?/
cvj
I use winscp on my lynux server to view and edit multiple text files using the internal editor..
what I would like to know is :- can I make some sort of batch file that will open multiple files to save me having to open all the files one at a time
thanks
Re: batch file to open multiple txt files within WinSCP ?/
Well, you can generate the URL. But in this case, I believe it's better to refer to your saved site on the command-line, to avoid duplicating the login info:
"C:\Program Files (x86)\WinSCP\WinSCP.exe" "site_name" /edit /remote/path/file.txt
cvj
Yeah thanks ,,
So can I do open multiple files on one line tho ?
"F:\WinSCP\WinSCP.exe" "BR" /edit /home/autoconfig.json config.json
cvj
yeah that I have seen and does help but I have to log in to server every time I start new instance/file tho,,,
is there no way this type of command can be executed from within WinSCP rather than from windows command prompt ?
cvj
ok now this I did already try tho. I can open each file as just one but both together ,, no
@echo off
"F:\WinSCP\WinSCP.exe" "BR" /edit /home/autoconfig.json; /home/config.js
I didn't write that you can use the semicolon with the command-line /edit switch.
You have asked if you can open multiple files from WinSCP, instead of commandline. I've assumed that you mean WinSCP GUI. And that's what my previous post shows.
cvj
Got it thanks for your patients !!
whilst you here how can i clear the lists in the drop down menu of the "shift f4" window ?
Use Ctrl+Del.
