S3 encryption support similar to SFTP
I use an S3 compatible service from Wasabi. Apparently there is a way to generate your own encryption keys for use with the service, so no one but the person with the key can access the data.
https://wasabi.com/wp-content/themes/wasabi/docs/API_Guide/topics/Object_Server-Side_Encryption.htm
Is there a way this could be implemented? I imagine it would work in the UI similar to the SFTP encryption UI does.
Thanks for a great app!
