Massive session password record
titi2612
Hi there !
I've created 200 WinSCP sessions but when I edit the file WINSCP.ini to add the password on each session (Password=XXXXXXXXX) it doesn't work. When I want to connect on a session, I need to enter the password again and again ...
Do you know how I can save the password in a persistant way ?
titi2612
Re: Massive session password record
Hi !
I've already try that but same issue.
It's like the checkbox "remember password" is not checked.
Regards
It works. If you have problem, we need more details to help you. Show us an example INI file and a corresponding session log file.
