Script for synchronization is working but does not exit
jan_van_man
I have an issue with a script that is synchronizing data from one server to another server. The script works and syncs the files and folders I want, but it doesn't exit. I have similar scripts running on the same server and they are all working fine and exiting.
@echo off
  /log="C:\WinScp\WinSCP.log" /ini=nul ^
  /command ^
    "open [SERVER_INFORMATION] ^
    "cd /" ^
    "lcd C:\Subscriptions\SFTP\FamClaimNumbers\Files" ^
    "synchronize local -filemask=*.*>10DS" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
