PowerShell script not downloading data but creates folder when in Task Scheduler
caghassi
I am trying to have files downloaded daily from SFTP to local and have it create a folder first then add the files to that folder. It works when not in Task Scheduler but task scheduler only creates the folder. Here is the code that I am using below.
$date = ((Get-Date).AddDays(-1)).ToString("MMddyyyy")
New-Item -Path "C:\Data" -Name $date -ItemType Directory
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Set up session options
    HostName = *********
    UserName = *********
    Password = *********
    SshHostKeyFingerprint = **********
try
    # Connect
    # Transfer files
    $remotePath = "C:\Data\$date\*"
    $session.GetFiles("/datafeed/*", $remotePath, $True).Check()
finally
Re: PowerShell script not downloading data but creates folder when in Task Scheduler
Do you get any error message? Please attach a full session log file showing the problem (using the latest version of WinSCP).
Btw, it should be $localPath, not $remotePath
caghassi
Session Log
It actually doesn't generate a session log. It looks like it just creates the folder then stops but I do not get an error in task scheduler.
  • Capture 3.PNG (10 KB, Private file)
  • Capture 2.PNG (28.36 KB, Private file)
