Delete File on Schedule
jgn
I'm new to this program and how to create/run scripts. Everything I've found for deleting a file is linked to an upload, download, or a sync. I don't have a triggering event, I just want to delete all files in a folder on my FTP everyday at 2pm. How would I go about doing that?
Thanks so much!!!
jgn
Re: Delete File on Schedule
So would this be the correct script then?
# Connect to SFTP server using a password
open sftp://ipaddresswithuser:2222/ -passive=on -hostkey="password"
# Delete file
rm ums_update.txt
# Exit WinSCP
The sftp is my ip and then the port... if I wanted to go into a specific folder would I just add that to the end of that link after the port? so :2222/folder/?
