SessionOptions.Password is set, but SessionOptions.UserName is not
Rick
  1. I can execute this script locally with success
  2. I have granted permissions for the account running the job on the folder.
  3. the job execute without any error, however does not synchronize local folder.
  4. when I run the script on the server from ISE i got this error:
    Error: Exception calling "Open" with "1" argument(s): "SessionOptions.Password is set, but SessionOptions.UserName is not."
Can you please help?
$localPath  = "\\folder1\log"
$remotePath = "/folder1/LOG"
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
$SId = 1
function get-psw{
    param(
        [String]$SID
    [Hashtable]$return = @{}
    #Get Username and Password
    $SS = ''
    $SSWS = New-WebServiceProxy -Uri $SS -UseDefaultCredential
    $Secret = $SSWS.GetSecret($SID, $false, $null)
    $psw = (($Secret.Secret.Items | Where-Object{ $_.FieldDisplayName -eq 'Password' }).Value)
    $usr = (($Secret.Secret.Items | Where-Object{ $_.FieldDisplayName -eq 'Username' }).Value)
    if (!$psw)
        $msg = "Couldn't get credentials"
        Write-Error -Message $msg -ErrorAction Stop
        exit 1
    return @{username=$username;password=$password}
try
    # Set up session options
        Protocol = [WinSCP.Protocol]::Ftp
        HostName = ""
        Username = $usr
        Password = $psw
        FtpSecure = [WinSCP.FtpSecure]::Explicit
    try
        # Connect
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False)
        # Throw on any error
        $synchronizationResult.Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: SessionOptions.Password is set, but SessionOptions.UserName is not
Are you sure this is a WinSCP question? I believe that the error indicates that your get-psw function does not work correctly in the ISE environment. What did you do to verify that the credentials are retrieved correctly?
