Console fixed font and font size
Legolasbite
Hello Martin.
Is there a way to have a font and a font size that are fixed/saved?
Every time i open a new console i have to change that because of the resolution of my monitors.
Predefining those would be great.
Thank you
Re: Console fixed font and font size
I'm not sure to what Console do you refer to. Do you mean WinSCP Console window?
https://winscp.net/eng/docs/ui_console
You can change font of that window using Interface\DefaultFixedWidthFontName and Interface\DefaultFixedWidthFontSize raw configuration options.
But as you cannot change the font of that window in GUI, and you claim that you are changing it, you possibly mean a different console window.
