How to use diffie-hellman-group-exchange-sha256 in the KEX=
lynn.hendricks@faithtechnologies.com
Wisconsin
when using the advanced key exchange selection,and picking diffie-hellman group exchange. then generating the seccion URL/code for powershell schript. it is putting KEX=dh-gex-sha1
How do I know that that is diffie-hellman-group-exchange-sha256?
shouldn't it be dh-gex-sha2 or dh-gex-sha256.
I need to make sure the key exchange I am using is:
===ssh-kex
diffie-hellman-group14-sha256
I've searched every where on WinSCP site, and see no formal statement of what setting to use inn the command KEX=.
thanks for any help with this.
Lynn...
Re: How to use diffie-hellman-group-exchange-sha256 in the KEX=
Thank you for the reply. i just wasn't sure it would use the 256,and didn't want a kick back, when we connect. because the site I'm connecting to, is changing to only except that encryption on the 30th.
thanks.
You do not have to do anything, if the server is changing its preferences. WinSCP and the server will automatically agree on the best mutually supported algorithms.
