Using COM library in Delphi
ragnor
I'm trying to use the library in Delphi. The server connection and file download works fine but once I want to access the collection of data such as “TransferOperationResult.Transfers” or “RemoteDirectoryInfo.Files” I’m not able to do it.
Could you please suggest the correct way accessing these data from Delphi?
Tomas
Re: Using COM library in Delphi
Cannot Delphi use .NET classes directly?
Anyway "I’m not able to do it" does not tell us much about the problem you are facing.
