Timestamp added to file name just stopped working.
capjlp
Kentucky, USA
Hi All
I had this script working daily for the past 3 years and its stopped doing what I expect.
It was putting the file over on my vendor's sftp and adding the timestamp in the file name.
Example Data202010291133.csv
Now its putting over Data%%TIMESTAMP#yyyymmddnnss%%.csv
Here is my command
 "put -nopermissions -nopreservetime C:\MyDirectory\Data.csv /Import/Data/Inbound/Data%%TIMESTAMP#yyyymmddnnss%%.csv"^
Any ideas on what changed again this script has been update in 3 years it last worked on 9/30 correctly then after that it started not doing what I expect.
Re: Timestamp added to file name just stopped working.
I guess someone downgraded your WinSCP installation to a version that does not support the %TIMESTAMP% syntax.
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
