Linux Docker Container Not Supporting Winscp
I have been using winscp(v5.17.8) in Dot Net Core(v 3.1) Background service to download the files from SFTP location. I don't have any issue when the service is running in windows.
But i need to deploy this service as linux docker container. I was able to build docker image successfully, But when i run the docker image i got this error from WinSCP where i am trying to download the file from SFTP location.
2020-10-30 14:55:15.1108|ERROR|RfrCalculation.RfrCalculationService|Exception occurred while executing RiskFreeRate Calculation The named version of this synchronization primitive is not supported on this platform. - at System.Threading.EventWaitHandle.CreateEventCore(Boolean initialState, EventResetMode mode, String name, Boolean& createdNew)
at System.Threading.EventWaitHandle..ctor(Boolean initialState, EventResetMode mode, String name, Boolean& createdNew)
at WinSCP.ExeSessionProcess.TryCreateEvent(String name, EventWaitHandle& ev)
at WinSCP.ExeSessionProcess.InitializeConsole()
at WinSCP.ExeSessionProcess.Start()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at Refinitiv.Financial.RiskFreeRate.Util.FtpUtility.DownloadFiles(String sourceDirectory, String sourceFilename, String localFileName) in /src/Util/FtpUtility.cs:line 126
at Refinitiv.Financial.RfrCalculationEngine.RfrCalculation.DownloadSourceFiles(String level) in /src/RfrCalculationEngine/RfrCalculation.cs:line 1455
at RfrCalculation.RfrCalculationService.ExecuteRiskFreeRateCalculation() in /src/RfrCalculation/RfrCalculationService.cs:line 64
Does winscp not support Linux docker container?
