System Error - Code 123
eddylit
I am experiencing a system error in my logs where it is not downloading all the files from an SFTP server.
I have attached the log; errors are at the end.
  • 2020-11-05_log.txt (6.83 MB, Private file)
Description: I have removed server and authentication details.
eddylit
Australia
Re: System Error - Code 123
Thanks for getting back to me Martin.
Would disabling the setting in the UI also affect scripts or would I have to add specific syntax to my scripts?
I only say this because I use scripts for everything and not the UI.
