KeepLocalUpToDate not working
niccoc1603
Hi, i am an absolute newbie.
I am trying to use this script but I get this error:
Exception calling "Open" with "1" argument(s): "Connection failed.
Peer certificate rejected
Disconnected from server
Connection failed."
I generated the sessionUrl which looks like this
ftps://xxx:xxx%21;fingerprint=xx-58-e7-2a-xx-77-30-xx-2e-00-2e-xx-67-7a-xx-fa-16-xx-xx-xx@12x.11x.xxx.xxx/
and copy/pasted into the script file
$sessionUrl = "ftps://xxx:xxx%21;fingerprint=xx-58-e7-2a-xx-77-30-xx-2e-00-2e-xx-67-7a-xx-fa-16-xx-xx-xx@12x.11x.xxx.xxx/",
but I still get the same error
any help?
[EDIT]
searching the forum I added the following string
$sessionOptions.TlsHostCertificateFingerprint = "xx-58-e7-2a-xx-77-30-xx-2e-00-2e-xx-67-7a-xx-fa-16-xx-xx-xx"
and it works now
Re: KeepLocalUpToDate not working
Can you please attach logs from both scenarios? (using the latest version of WinSCP).
niccoc1603
Ok logs attached, thank you
  • winscp_no-TlsHostCertificateFingerprint.log (4.94 KB, Private file)
  • winscp_with-TlsHostCertificateFingerprint.log (36.19 KB, Private file)
Actually, I've realized that 5.17.8 indeed does not support the "fingerprint" in the FTPS URL. It's fixed in upcoming 5.18. But with 5.17.8, you should get
Exception calling "ParseUrl" with "1" argument(s): "SSH host key fingerprint "xx-xx-xx-..." does not match pattern /..../"
Did you tamper with the script somehow to avoid this error?
I'm adding the (already fixed) issue to the tracker, now that you have faced it:
https://winscp.net/tracker/1925
niccoc1603
HI, what I did was adding the following string to the script, and it works
I understand that.
What I do not understand is, how you got the log file, where you claim to use the URL with the fingerprint and not the $sessionOptions.TlsHostCertificateFingerprint. Because with the URL with the fingerprint, the script should break at the very beginning, without creating any log file.
