Session Open is slow
danfee
m_sessionOptions = new SessionOptions
    Protocol = Protocol.Sftp,
    HostName = sftpServerIP,
    UserName = sftpUserID,
    Password = sftpPassword,
    PortNumber = 2222,//默认2222端口
    GiveUpSecurityAndAcceptAnySshHostKey = true
    session.SessionLogPath = @"D:\test\upload\log.txt";
    session.Open(m_sessionOptions);
It takes 1~2 second to open session,can it be faster?
Re: Session Open is slow
I wouldn't call 1-2 second connection to a remote SSH/SFTP to be slow. Do you have a reason to believe it should be faster?
If you want us to investigate further, please attach a full session log file.
