failure accessing onedrive
Re: failure accessing onedrive
rmuller wrote:
never mind, i solved it using an app password
Thanks for sharing your solution. Can you please give us more information about what is the "app password"?
madjo1983
I tried on my side but not wortking. Did you put the password app on the password field and let all other fields as the onedrive config post or did you proceed with other modification ?
