Can't get attributes of file...
LeGlubert
Swiss
I receive this error message
'Can't get attributes of file '/G.Collection/1_3_1_0/Setup.exe'.
Could not retrieve file information
'/G.Collection/1_3_1_0/Setup.exe' cannot be listed'
I use C#, note that if I download another file, for example Setup.msi, everything is fine.
I use the latest version, Visual Sutdio 2019
At your disposal for any further information
Amitiés
Lionel
Re: Can't get attributes of file...
All I can see in the log is that the server fails to provide file attributes:
> 2020-11-16 14:33:19.281 MLST /G.Collection/1_3_1_0/Setup.exe
< 2020-11-16 14:33:19.482 550 '/G.Collection/1_3_1_0/Setup.exe' cannot be listed
I cannot tell why. Please contact your server administrator.
LeGlubert
Swiss
thank you, but this I knew, this is the error message I was getting...
and, it works OK with a *.msi file, it works if I use "Setup*.exe", and it works with another library...
Amitiés
Lionel
