Preserve Timestamp Staying Enabled for Synchronize
joe@lavalleassociates.com
New York
I am unable to disable Preserve Timestamp in the Common Options or via C# code when using Synchronize. This seems to be a new issue that I have not seen before. I am running 5.17.8.
Even if I select transfer settings I have configured the Preserve Timestamp still stays enabled and I cannot uncheck.
Joe
Re: Preserve Timestamp Staying Enabled for Synchronize
Can you please give us step-by-step instructions for reproducing the problem?
Btw, are you aware that the "Use same options next time" does not apply to the transfer settings? (and it never did) – That's why it's above the box.
See https://winscp.net/eng/docs/ui_synchronize#saving_options
Also I do not understand the relation to "C# code".
New York
Using the UI, when I synchronize I look at the default Transfer Options and the Preserve Timestamp is always checked and grey, even if I select or configure a different one and uncheck it does not persist.
My c# code has this specified but I think I am missing something as it will not respect the synOptions.PreserveTimestamp = false.. I get the errors below
SynchronizationResult synchronizationResult;
TransferOptions synOptions = new TransferOptions();
synOptions.FileMask = filemask;
synOptions.PreserveTimestamp = false;
synchronizationResult = session.SynchronizeDirectories(SyncMode, sourcefolder, destinationfolder, false, false, WinSCP.SynchronizationCriteria.Time, synOptions);
try
   synchronizationResult.Check();
   logfile.WriteLine(DateTime.Now + " : Remote Sync Result : {0}", synchronizationResult.ToString());
catch (Exception e)
   logfile.WriteLine(DateTime.Now + " : Error Obtaining Sync Result  : {0}", e.Message);
11/16/2020 10:17:46 AM : Error Obtaining Sync Result  :
**Upload of file 'File11.20201112.1342.txt' was successful, but error occurred while setting the permissions and/or timestamp.
If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
The server does not support the operation.
Error code: 8
Error message from server (US-ASCII): SETSTAT unsupported
