Synchronize to S3
ben@eds
USA
Synchronize to S3
Hi Martin,
Is it possible to Synch to an S3 sftp site on AWS? I see from the docs there is limited functionality, but can't tell if it is supported for any.
Ben
Re: Synchronize to S3
Do you have any specific problem? What docs are you specifically referring to?
In general, S3 does not support setting remote file timestamps. What limits (but not prevents) the synchronization. I'm not sure about SFTP for S3, but I assume it does not support it either.
