[SOLVED] Winscp .Net assembly - Error transferring file
glannes
We receive files on our system , rename it and send through SFTP using WinSCP .NET assembly. We use WinSCP in a PowerShell script.
Sometimes when we received two files in the sametime, we have this error message:
'SourcePath'. Copying files to remote side failed. Can't open data connection for transfer of "/FILENAME_date_hours""
Do you have any idea that what is happened ?
Regrds,
Re: Winscp .Net assembly - Error transferring file
glannes
Hello Martin,
I will post you the session log when the problem occurs again.
Is there a risk of having a message like "process used" if the log session is called several times at the same time?
Regards
Guillaume
If you run multiple processes in parallel, each should log to an unique log file.
glannes
Please find the log generated by the SessionDebugLog.
Could you help me to understand why it failed?
Regards,
  • winscpFODLE00400002_10122020_9323065.log (101.71 KB, Private file)
I was asking for Session.SessionLogPath. You have posted Session.DebugLogPath.
glannes
Hello ,
Please see the error file
  • winscpFODLE00400003_07012021_9330248.log (9.14 KB, Private file)
I have asked for Session.SessionLogPath, you have posted Session.DebugLogPath (there's no SessionDebugLog).
glannes
What??? no it's session LogPath. Could you share me what do you see in the file ?
In the file, i have PASV line , Port line etc..
Sorry, my mistake, I was reading your old posts.
It might be a firewall issue. Your server has some problems with the passive mode, so WinSCP falls back to the active mode. You might not have all the active mode ports open in your local firewall. See https://winscp.net/eng/docs/ftp_modes#active
Though better would be to get your FTP server fixed to support the passive mode.
Both. The passive mode problem is on the remote side.
And the active mode problem is probably on your side.
glannes
For your information,
the problem was in the remote side. It was a router badly dimensioned and constantly at 100% CPU that can cause IP losses.
Thanks a lot for your help
Have a nice day
