PutFileToDirectory fails with []
Speed103
Lafayette, LA
I'm trying to use the PutFileToDirectory method in my C# program. However, it fails on files with square brackets in the name, like Test[4]. I assumed it was a filemask issue but I can't use RemotePath.EscapeFileMask because it only takes the original filename and then the remote directory. Also, the documentation seems to indicate:
You specify a path to the source file, not a wildcard, so you do not need to escape a literal file name.
Is this is a bug or am I missing something I need to set to send these files?
Thanks!
Speed103
Lafayette, LA
FYI...here's an example exception when trying to execute:
ftpSession.PutFileToDirectory(@"C:\Temp\test[4].txt", "/");
I get:
Unhandled Exception: WinSCP.SessionRemoteException: File or folder 'C:\Temp\test[[]4].txt' does not exist.
If I manually call RemotePath.EscapeFileMask(filename), it appears it converts my filename to the name in the exception, so I'm thinking PutFileToDirectory automatically calls that on the local file parameter, but is not escaping correctly with square brackets?
Speed103
The fix worked. I assume it will take a while to make it into the NuGet repo? I worked around it by using PutFiles but would like to change it back to PutFileToDirectory when I can since the syntax is simpler as your documentation has noted.
Manurobate
France
Hi there,
I have exactly the same probleme. Could you please send me the development version of WinSCP to fix my problem ?
If not, do you know when the fix will be release ?
Thanks for your help.
