Keep remote directiory up to date
mudo
There's a little Bug in "Keep remote directiory up to date"-Function.
I saved all my connections with Name like "example.com [Customers Name, eg.]"
So when i connected, i often use the option "Keep remote directiory up to date" and click the 'Start'-Button. That's work fine. But if i click 'Start in New Window' instead, i'll get the Error:
Host "Customers Name, eg.]" not available.
It seems, you are using the connecion name after its first space as hostname.
Regards
Re: Keep remote directiory up to date
Thanks for your report. Though, I cannot reproduce the problem. What version of WinSCP are you using?
mudo
Hey Martin,
oooh i have the solution right now ;-)
So i used the WinSCP Version 5.17.7 (Build 10640) - the Portable Version that i downloaded from portableapps.com at the time.
Now i downloaded 5.17.9 from winscp.net and kept the WinSCP.ini. With this Version there is no problem any more.
Thank you
