SCP login hangs with "su" command
brooky
Cambridge, UK
If I login to my server as root using SSH keys over SCP (not SFTP) without password I would expect to be able to use the console to change user.
Say for example I have 100 hosting accounts on the server and I want to login as that user. The most efficient way is to login as root then "su username".
With shell access for that user disabled the console correctly tells me that shell isn't allowed. If it is allowed it hangs. Screenshot attached.
Re: SCP login hangs with "su" command
This is not possible. You cannot execute shell commands in an SFTP session. The "Console" actually opens a separate shell session:
https://winscp.net/eng/docs/shell_session
Even if you succeeded in doing "su" there, it would have no effect on the SFTP session.
There's no way to change the user in a middle of SFTP session.
See also https://winscp.net/eng/docs/faq_su
