connection closed from remote server without any errror. Please help
mnaveen
India
"C:\Program Files (x86)\WinSCP\WinSCP.com" /rawconfig Interface\SessionReopenAutoStall=2000 /log="D:\old\winscp_log\winscp_%yymmdd_hhmmss%.log"  /command ^
    "option batch abort" ^
    "open ftps://****@***.com:%Password%@****.sharefileftp.com -hostkey="8c:6e:4a:04:d7:42:5f:eb:88:72:e0:22:91:a4:f2:72:fd:f1:0e:83" -passive=on" ^
    "get -preservetime -resume -speed=2250 /ECC/PITR/WAL_ARCHIVE E:\ECC\PITR\WAL_ARCHIVE" ^
    "exit"
Log is below
2020-12-19 20:23:17.215 226 Closing data connection.
. 2020-12-19 20:23:17.215 Warning: Timezone difference was not detected yet, timestamps may be incorrect
> 2020-12-19 20:23:17.215 TYPE I
< 2020-12-19 20:23:17.262 200 Binary mode selected.
> 2020-12-19 20:23:17.262 PASV
< 2020-12-19 20:23:17.324 227 Entering Passive Mode (54,254,202,61,215,126)
> 2020-12-19 20:23:17.324 REST 37017
< 2020-12-19 20:23:17.387 350 Will restart at offset 37017; send RETR command.
> 2020-12-19 20:23:17.387 RETR 0000000100000012000000AD.gz
. 2020-12-19 20:23:17.387 Connecting to 54.254.202.61:55166 ...
< 2020-12-19 20:23:17.774 125 Secure data connection open; transfer starting.
< 2020-12-19 20:23:17.915 426 Connection closed; transfer aborted.
. 2020-12-19 20:23:17.915 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
. 2020-12-19 20:23:17.915 Copying files from remote side failed.
* 2020-12-19 20:23:17.915 (ExtException) **Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
* 2020-12-19 20:23:17.915 **
* 2020-12-19 20:23:17.915 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
* 2020-12-19 20:23:17.915 Copying files from remote side failed.
* 2020-12-19 20:23:17.915 Connection closed; transfer aborted.
. 2020-12-19 20:23:17.915 Asking user:
. 2020-12-19 20:23:17.915 Error transferring file '/ECC/PITR/WAL_ARCHIVE/2018-05-29/0000000100000012000000AD.gz'. ("Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
. 2020-12-19 20:23:17.915 ","Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
. 2020-12-19 20:23:17.915 ","Copying files from remote side failed.","Connection closed; transfer aborted.")
< 2020-12-19 20:23:17.915 Script: Error transferring file '/ECC/PITR/WAL_ARCHIVE/2018-05-29/0000000100000012000000AD.gz'.
< 2020-12-19 20:23:17.915 Script: Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
< 2020-12-19 20:23:17.915 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES128-SHA, 2048 bit RSA, ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
< 2020-12-19 20:23:17.915 Copying files from remote side failed.
< 2020-12-19 20:23:17.915 Connection closed; transfer aborted.
Reply with quote E-mail
Re: connection closed from remote server without any errror. Please help
You keep posting the same questions all over this forum, Stack Overflow, Super User, and who knows where else. And whenever we ask you for more information, instead of providing them, you re-post your question elsewhere.
Regarding this problem, I've already asked you on this forum:
Please attach a complete log file from the latest version of WinSCP. Did you try any other FTP client?
Also on Stack Overflow (you have deleted the question meanwhile):
Can you retrieve the directory listing from the FTP server anyhow? In WinSCP GUI? In any other FTP client? If you can, show us a log file for that successful listing.
