internal editor -- file navigation
labumm
Norman, OK
Can you add home and end keys for file navigation? "home' to go to the beginning of the file and "end" to go to the end.
Re: internal editor -- file navigation
I'm not sure I understand. You can jump to the beginning and to the end using Ctrl+Home and Ctrl+End, as in most editors. The Home and End are for jumping to the beginning and end of the current line.
