WinSCP fails to launch
monstuh
Texas
Running into an issue where WinSCP will fail to launch consistently. Getting the following in Event Viewer:
Faulting application name: WinSCP.exe, version: 5.17.9.10905, time stamp: 0x00000000
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc000001d
Fault offset: 0x0001032a
Faulting process id: 0x169c
Faulting application start time: 0x01d6dd55917f0875
Faulting application path: C:\Temp\WinSCP-5.17.9-Portable_2\WinSCP.exe
Faulting module path: unknown
Report Id: 9fc5dc94-b219-4140-a801-9546814dff35
Faulting package full name:
Faulting package-relative application ID:
I have tried various version including the latest portable version, all with the same results.
Running this on Server 2016. If I attempt to launch the executable enough times, it does does but on the very next attempt, it fails.
From the minidump:
Exception Code: 0xC00001D
Exception Information: The thread tried to execute an invalid instruction.
Heap Information: Not Present
After further troubleshooting, found the issue appears with specific version of VMware Horizon View (7.10.3). Validated that with older versions of VMware Horizon, WinSCP loads without issue.
Re: WinSCP fails to launch
monstuh
Texas
Thank you. Upon running the executable you provided, I am prompted with same Windows error message. Which is what I have encountered with the full / portable client. If I attempt to launch the executable enough times, the application does load successfully.
The attached log file is from a successful launch of the application and once it loads, I have no problems.
To clarify, the problem occurs when attempting to launch WinSCP. Functionality of the application is not an issue.
monstuh
Texas
Update... Got a workaround from VMware that resolved my issue.
The workaround essentially excludes WinSCP from hooking ftapihook32.DLL, the Serial Port and Scanner redirection, on the server.
In the Registry Editor, navigate to
HKLM\SYSTEM\CurrentControlSet\Services\ftsjail\ExcludeProcesses
Add *\winscp.exe
Restart
