WinSCP "Not Responding" every time
Dan12071207
Hi
I'm trying to use WinSCP Version 5.17.7 (Build 10640). I'm able to login into my server fine but as soon as I try to click anything else once logged in, it goes to "Not Responding" and I can't use it at all and have to kill the program. This has been happening since I first installed it approx. 4 months ago.
Reply with quote E-mail
Re: WinSCP "Not Responding" every time
nagyp1119
Similar issue
Hello!
I have a similar problem with winscp. The software freezes for a minute or so after every major action or file transfer. I reinstalled it several times and tried different transfer settings but nothing really helped. Intrestingly, I'm only having this issue on one of our several identical PCs.
Thanks for your help!
Re: Same problem
cerber wrote:
I am having the same problem. Please help!
I have sent you the debug build too.
