Scripting get command executing invalid commands causing missed files
kbannert
i have written a script that by default runs with option batch continue as a stop gap incase one of the ftp server i connect to errors out.
i have noticed that recently, the get command, when provided a full remote path with filename is causing errors with some ftp servers.
i have it written as such:
get "/Remote/Path/to/System.ini" "C:\Local\Path\for\System.ini"
in the logs, its executed as such:
>  Script: get "/Remote/Path/to/System.ini" "C:\Local\Path\for\System.ini"
.  Listing file "/Remote/Path/to/System.ini".
.  Retrieving file information...
>  PWD
<  257 "/"
>  CWD /Remote/Path/to/System.ini
<  550 Requested action not taken: internal server error
>  TYPE I
<  200 Type set to I.
>  SIZE /Remote/Path/to/System.ini
.  Could not retrieve file information
<  Script: Can't get attributes of file '/Remote/Path/to/System.ini'.
<  Could not retrieve file information
as you can see, the CWD is including the filename as a directory that can be changed to. i had attempted to mitigate this by changing my script to the following:
cd "/Remote/Path/to/"
get System.ini "C:\Local\Path\for\System.ini"
yet the get command still performs the CWD with the full path that i had JUST done a CD prior to attempt to bypass this bug with.per the logs
> Script: cd "/Remote/Path/to/"
. Changing directory to "/Remote/Path/to/".
< 250 Requested File Action Completed OK
> PWD
< 257 "/Remote/Path/to"
< Script: /Remote/Path/to
> Script: get System.ini "C:\Local\Path\for\System.ini"
> PWD
> TYPE I
< Script: Can't get attributes of file 'System.ini'.
the servers(4)im dealing with that throw this error use Twisted 15.5.0 FTP Server. this also errors on Windows 9x/NT FTP server, however the server still responds to the size command properly and allows the transfer of the file. the feature set im limited to is as follows:
< 211-Features:
<  FEAT
<  MDTM
<  PASV
<  SIZE
<  TYPE A;I
this issue dose not occur on the Unix emulated FileZilla FTP Server, as i see it properly performing a CWD without the file included as a directory. Is there a way to fix this?.
Re: scripting get command executing invalid commands causing missed files
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
