Checking for updates hang then shows Certificate not trusted
Rhialto
Donor+
Québec, QC - CANADA
I use WinSCP only a few times a year and I had version 5.17.7 installed from last time and proceeded to check for updates but application hang there a while then shows an error about certificate not trusted. I thought it could be a problem with that version so I downloaded and installed 5.17.9 but same thing.
Since I don't see recent posts about this maybe it's on my end only? I know it was an issue in the past but should be fixed now, I think?
Maybe it's temporary? I'll try again in a few days...
FirstUse=2021-01-24T02:21:47.820Z
FirstVersion=517090000
LastReport=2021-01-24T02:21:47.820Z
LastUpdateException=Certificate not trusted.
Error: 80092013, Chain index: 0, Element index: 0
Server certificate verification failed: issuer is not trusted
ThemeMessageFontSize=9
ThemeMainInstructionFontSize=12
PeriodUpdateCertificateErrors=1
PeriodUpdateChecksFailed=1
LifetimeUpdateCertificateErrors=1
LifetimeUpdateChecksFailed=1
