Hello, connect/ get
sys
Cluj_Napoca
Hello, connect/ get
Hello guys, I have this powershell code.
Works good but when add more line in db.csv doesn't work with return error code:
Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "username".
Authentication failed."
At C:\Users\me\Desktop\testeScript\CollectLog.ps1:41 char:5
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SessionRemoteException
When I have per example only 2 line in db.csv the script works very well
HostName,IP
name1,10.10.1.1
name2,10.10.1.2
I try with 19 hostname and Ip addr line in CSV doc and works, but when I add only 1 more stopping works.
19 works
20+ doesn't work..
Any idea? (Thank you and sorry for my english)
Add-Type -Path "WinSCPnet.dll"
$Name = @()
$ip = @()
Import-Csv db.csv |`
    ForEach-Object {
        $Name += $_.HostName
        $ip += $_.IP
$inputID = Read-Host -Prompt "Type ID"
if ($Name -contains $inputNumber)
    $Where = [array]::IndexOf($Name, $inputID)
    Write-Host "IP: " $ip[$Where]
# Set up session options
    HostName = "$ip"
    UserName = "username"
    Password = "password"
    GiveUpSecurityAndAcceptAnySshHostKey = "true"
try
    # Connect
    # Transfer files
    $session.GetFiles("/C:/Program Files/Common Files/logs/Device.log", "E:\loguri\Log\Arhive\*").Check()
finally
    $session.Dispose()
Compress-Archive -Path "E:\loguri\Log\Arhive\Device.log" -DestinationPath "E:\loguri\Log\Arhive\$inputID.zip" -Update
Remove-Item -Path "E:\loguri\Log\Arhive\Device.log" -Force
Re: Hello, connect/ get
Please attach logs of the 19th (successful) and 20th (failed) connections.
And then a log of a session with the same settings as the 20th connection, but when used as the only connection (supposedly successful).
sys
Cluj_Napoca
Hello Martin,
First of all , thank you in advance for your time and your reply :D
I Attach logs
1x log with Fail.
1x log with Succeed.
Have a nice day :)
  • winscpOK.log (12.53 KB, Private file)
  • winscpFAIL.log (5.88 KB, Private file)
Thanks for the logs.
sys
Cluj_Napoca
Hello Martin,
Thank you for your interes.
I fix the problem with new method search in db.csv.
I leave my updated script ; maybe can help someone
$db = import-csv -Path "C:\Program Files (x86)\WinSCP\db.csv"
$inputID = Read-Host -Prompt "ID"
$entry = $db -match $inputID
    $User = "username"
    $Password = "password"
    $Command = "command if you want (SSH)"
    $secpasswd = ConvertTo-SecureString $Password -AsPlainText -Force
    $Credentials = New-Object System.Management.Automation.PSCredential($User, $secpasswd)
Get-SSHTrustedHost | Remove-SSHTrustedHost
$SessionID = New-SSHSession -ComputerName $entry.IP -Credential $Credentials -AcceptKey:$true
Invoke-SSHCommand -Index $sessionid.sessionid -Command $Command
    HostName = $entry.IP
    UserName = "$User"
    Password = "$Password"
