Multiple File Mask for WinSCP Session.EnumerateRemoteFiles
febesuvu
Winigan
I am rebuilding the FTP part of a performance monitor application, should be able to upload any file with extensions
.csv .xlsx .xls
and when i try to customize this mask it returns 0 files, but if i select only one of them it works fine.
string FileMask = "*.csv; *.xlsx; *.xls";
var sessionOptions = new SessionOptions
    Protocol = Protocol.Sftp,
    HostName = ConfigurationManager.AppSettings["FtpHost"],
    UserName = ConfigurationManager.AppSettings["FtpUsr"],
    Password = ConfigurationManager.AppSettings["FtpPwd"],
    SshHostKeyFingerprint = ConfigurationManager.AppSettings["SshHostKeyFingerprint"]
    session.Open(sessionOptions);
    List<string> files =
        session.EnumerateRemoteFiles("/", FileMask, EnumerationOptions.AllDirectories)
        .Select(fileInfo => fileInfo.FullName)
        .ToList();
    Console.WriteLine($"Found {files.Count} files");
Re: Multiple File Mask for WinSCP Session.EnumerateRemoteFiles
The Session.EnumerateRemoteFiles supports a single mask only. If you need to use multiple masks, you will have to enumerate all files and select those you want yourself in your code.
