The process cannot access the file '...wscp134C.003E8D9B.tmp' because it is being used by another
karthiga
Following is the error message:
The process cannot access the file '...\AppData\Local\Temp\wscp134C.003E8D9B.tmp' because it is being used by another process.
System.IO.IOException: The process cannot access the file '...\AppData\Local\Temp\wscp134C.003E8D9B.tmp' because it is being used by another process.
at System.IO.__Error.WinIOError
at System.IO.FileStream.Init
at System.IO.FileStream..ctor
at WinSCP.PatientFileStream..ctor
at WinSCP.SessionLogReader.OpenLog
Version of WinSCP: 5.17.9
Any assistance please?
Re: The process cannot access the file '...wscp134C.003E8D9B.tmp' because it is being used by another
Please set Session.DebugLogPath and attach the log here.
I do not see any error in the log. Is this a log for the session that failed with the exception you have included in your first post?
karthiga
I tried again, but when this error occurred, it stopped adding the logs. I added the error details.
  • error.txt (6.17 KB, Private file)
So do you mean that it works sometimes (most of the time?) and then it suddenly stops working? You never mentioned that. Please give us more details.
karthiga
It is working and writing the logs in debug log file, but when this error comes, I can't see any logs after that in the debug log file. The error shows in Stackify. I attached Stackify error details in my previous message.
Please double check that. If WinSCP .NET assembly were not able to create a debug log, it would throw a corresponding exception. What does not seem to be happening, as you get another exception much later when the debug logging is already started.
