Installer creates temporary directory+files in current directory that persist after installation
                When executing the WinSCP installer it always creates a temporary folder like
It would be nice to configure the installer to not dump files in the local directory (temporary files should better be saved to the
        scoped_dir13440_1140471795 in the current folder with files in it that is never cleaned-up.
%TEMP% directory where Windows can delete them automatically) or at least clean-them up after installation finishes.
