How to set ShowHiddenFiles from /rawconfig
netinial
I was wondering if help us,
We are starting WinSCP from KeePass with following CMD, however ShowHiddenFiles comes false as default. How can we change it from false to true without ini file?
cmd://"..\..\WinSCP\WinSCP\WinSCP.exe" sftp://user:pass@domain:/username/web1/ /rawsettings LocalDirectory=themes\theme /ini=nul /rawconfig Interface\ShowHiddenFiles=True
does not works
Second Question is
There was a shell command however no example at RawSetting.
How to use /Shell flag from Cmd Startup as follow?
cmd://"..\..\WinSCP\WinSCP\WinSCP.exe" sftp://user:pass@domain:/username/web1/ /rawsettings LocalDirectory=themes\theme /ini="..\..\settings.ini" /Shell="sudo -u username -s"
/Shell=sudo -u username -s
or any variants does not works
Re: How to set ShowHiddenFiles from /rawconfig
It's not True, but 1 (or on, since WinSCP 5.18.1):
/rawconfig Interface\ShowHiddenFiles=1
The same way as LocalDirectory:
/rawsettings LocalDirectory=themes\theme Shell="sudo -u username -s"
netinial
Thank you for your fast response Martin.
I appreciated.
Note for others :
Shell
This code does not work with SFTP protocol but SCP.
