Occasional Timeout
I am using the .NET assembly in a worker server to transfer files as needed. I am using 5.17.9 of the WinSCP.
I have a SMTP connection that occasionally will timeout after 15 seconds. I am not specifying the timeout in code (C#) but I read that the default timeout on the Session is 60 seconds. Is that still the case or how would I fix the following issue? I'm guessing increase the Session and sessionoptions timeouts? Do I set both? Here is part of the log when it is trying to copy a file from the SMTP server:
. 2021-02-18 08:35:49.387 Waiting for data timed out, asking user what to do. . 2021-02-18 08:35:49.387 Asking user: . 2021-02-18 08:35:49.387 **Host is not communicating for 15 seconds. . 2021-02-18 08:35:49.387 . 2021-02-18 08:35:49.387 Wait for another 15 seconds?** () < 2021-02-18 08:35:49.387 Script: Host is not communicating for more than 15 seconds. < 2021-02-18 08:35:49.387 Still waiting... < 2021-02-18 08:35:49.387 Note: If the problem repeats, try turning off 'Optimize connection buffer size'. < 2021-02-18 08:35:49.387 Warning: Aborting this operation will close connection! . 2021-02-18 08:36:50.700 Attempt to close connection due to fatal exception: * 2021-02-18 08:36:50.700 **Terminated by user.** . 2021-02-18 08:36:50.700 Closing connection. . 2021-02-18 08:36:50.700 Sending special code: 1 . 2021-02-18 08:36:51.262 Connection was lost, asking what to do. . 2021-02-18 08:36:51.262 Asking user: . 2021-02-18 08:36:51.262 **Terminated by user.** () < 2021-02-18 08:36:51.262 Script: Terminated by user. . 2021-02-18 08:52:01.465 --------------------------------------------------------------------------
