Script to send / receive is not working.
I'm using Task Scheduler to automaticaly send and download files at many customers. At one site my scripts stopped working 18.02.2021. I have tried another server at the same customer with the same result. The 2 servers I have problem with are running OS Windows 2012 R2 and OS Windows 2008 Build 6003, and both are up to date regarding Windows Update.
The Task Scheduler is not reporting any problems and the scrips do all their local file handling. WinSCP dos not creating the logfile I have asked for in the Script. The PUT and GET command is not being executed. By running the scripts manually it looks OK but no transfer are executed.The scrips are exactly the same on many installations.
Scripts are attached.
Does anyone have an idea of what is wrong?
