Error while uploading a 120GB file
jmar83
jmar83 avatar
Switzerland
System: Debian 10 with mout current updates on current VirtualBox Version 6.1.18 without Guest Additions Drivers but with VirtualBox Extension Pack
Upload from: Host system (so NO physical network connection just from VM host to VM)
WinSCP version: Most current from today
Note: It doesn't seem to be an SSH server-side problem, i can re-connect without any problems after that error occurs...
Thank you for your feedback.
With best regards,
Jan
jmar83
jmar83 avatar
Switzerland
The problem was that the space on the target OS disk was full.
Maybe you can replace that suspicious with a error message that contains a text
Error XXX
Maybe the space on the target machine is empty
Or whatever...
Regards, Jan
