Connection test failed. cURL Error: TCP connection reset by peer
alkraida
saudi arabia
Hi
I recently installed the WinSCP.
I am facing a problem when adding a new server and this error appears
Nilpo
New Springfield, OH
Double check your connection settings. This usually occurs when the remote server rejects your connection request. Are you able to connect using SSH from a terminal?
Re: Connection test failed. cURL Error: TCP connection reset by peer
Where do you get that error? This does not look like a WinSCP message.
