WinSCP.exe crashes when ls into remote folder with many files
Wlad
Hey WinSCP Team,
I am having a Problem with WinSCP Version 5.17.10 (Build 11087).
When trying to access a folder with more than >200 files WinSCP GUI crashes to desktop or maybe just the session ends. I tried to go through the logs but couldn't find any trace to further debug. After that I tried to connect via commandline and the WinSCP.com ends/crashes after I do ls of the directory with many files (>200).
I can say that another directory with 139 files does update correctly.
Please find attached a log of my cmdline session where you can see how ls on /BACKUPS/Duplicati/MyDocumentsBup (139 files) works but /BACKUPS/Duplicati/AllPicsBup (>200 files) does abort! Last lines of the log.
  • WinSCP_log_MyFritz_cmdline.txt (161.63 KB, Private file)
Description: Command line session. First LS on /BACKUPS/Duplicati/MyDocumentsBup than ls on /BACKUPS/Duplicati/AllPicsBup
Re: WinSCP.exe crashes when ls into remote folder with many files
