Download only 'new' or 'modified' files
lintho
Hello!
After some great help from you Martin last year I managed to get my scripts working in pipelies in devops (Azure).
However, the downloading\uploading part is taking a loong time when im trying to deploy new versions of my websites.
This is my current script – which is downloading files from a folder on production web app, to a staging slot before swapping the slots.
$ftp = '$(hostname)'
$user = '$(produser)'
$pass = '$(prodpass)'
$folder = 'site/wwwroot/wwwroot/images/uploaded/*'
$sitenameFolder =  '$(sitename)'
$target = "C:\"+ $sitenameFolder+"\*"
Write-Host $target
# Load WinSCP .NET assembly
Add-Type -Path  "$(System.DefaultWorkingDirectory)/drop-yaml/drop-yaml/ftp/WinSCPnet.dll"
# Setup session options
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = $ftp
    UserName = $user
    Password = $pass
try
    # Connect
    # Download files
    $transferResult = $session.GetFiles($folder, $target)
    $transferResult.Check()
    # Print results
    foreach ($transfer in $transferResult.Transfers)
        Write-Host "Download of $transfer succeeded"
finally
    # Disconnect, clean up
    $session.Dispose()
and for upload:
$user = '$(destinationuser)'
$pass = '$(desinationpass)'
$fromFolder= "C:\"+ $sitenameFolder+"\*"
Write-Host $fromFolder
    HostName = $ftp
    UserName = $user
    Password = $pass
try
    # Connect
    $remotePath = $fromFolder
    $transferResult = $session.PutFiles(($fromFolder + "*.*"), ($folder + "*.*"), $False)
        Write-Host "Uploaded of $transfer succeeded"
finally
    $session.Dispose()
Is there any way to optimize this?
lintho
Hello.
Thanks for a quick reply! I will check it out.
I thought this was clear:
But, on the website it its possible to upload files directly to a folder on the site. When i am deploying new versions of my website using CD/CI, i am using 'slots' in azure, so my staging slot is replacing the production website. If i do that without transferring files using WinSCP, all files uploaded to the website ends up on the staging slot, and is NOT on production anymore. Therefor i am downloading all files from prod, and uploading them to staging slot, before i replace staging with prod.
lintho
So, instead of downloading all files, is it possible\faster to check filesum on files or something so I don't have to download all files?
lintho wrote:
But, on the website it its possible to upload files directly to a folder on the site. When i am deploying new versions of my website using CD/CI, i am using 'slots' in azure, so my staging slot is replacing the production website. If i do that without transfering files using winSCP, all files uploaded to the website ends up on the staging slot, and is NOT on production anymore. Therefor i am downloading all files from prod, and uploading them to staging slot, before i replace staging with prod.
I do not know anything about this, so I cannot advise.
Theoretically yes, but most FTP servers do not support this. If your FTP server don't, you might build a service that provide the checksums and use it on your PowerShell script to choose the files to update. But in that case you might have the service automatically pull the updated files from the source, and you won't need the local intermediate PowerShell/WinSCP script.
