Unable to change the directory through script using lcd command
agadkari
India
Hi All,
Greetings for the day!!
I am trying to download files sftp server to my local machine, with created a date-wise folder.
But it's falling at the point of lcd.
Here is my script.
@echo off
set datetime=%date:~7,2%%date:~4,2%%date:~10,4%
set "mydir=D:\Test\%datetime%\"
mkdir "%mydir%"
echo My Directory is created "%mydir%"
  /log="D:\temp\WinSCP.log" /ini=nul ^
  /command ^
   "open sftp://username:password@sftp.server1/logs/Test/ -hostkey=""ssh-key=""" ^
"lcd %mydir%" ^
    "get *.xml>1D" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Here is the Error Code:
> 2021-03-18 09:17:10.392 lcd D:\Test\18032021\
< 2021-03-18 09:17:10.392 Script: Unknown command '
< 2021-03-18 09:17:10.392 lcd'.
. 2021-03-18 09:17:10.393 Script: Failed
. 2021-03-18 09:17:10.393 Script: Exit code: 1
. 2021-03-18 09:17:10.393 Closing connection.
. 2021-03-18 09:17:10.393 Sending special code: 1
. 2021-03-18 09:17:10.579 Session sent command exit status 0
. 2021-03-18 09:17:10.579 Main session channel closed
. 2021-03-18 09:17:10.580 All channels closed
I tried with many options but it's still failing. Any suggestion pointer much appreciated.
Regards,
Aniruddha
Re: Unable to change the directory through script using lcd command
See https://winscp.net/eng/docs/faq_batch_file#newline_escaping
Your duplicate (and answered) question on Stack Overflow:
Some WinSCP commands in a batch file are not working
Though here you have posted a batch file with syntax that will indeed produce the error you are describing. On Stack Overflow you did not preserve the exact indentation, so the error did not make sense.
