Keep Remote Directory up to Date - Startup script
sysmgts
uk
Hi
I am currently using 'Keep Remote Directory up to Date' via the GUI, leaving the user logged into the server to keep the service running.
What is the best method to make sure the service automatically restarts if the server is rebooted? If I create a script with keepuptodate will this run in the console rather than GUI, even if a user signs back into the server??
Many thanks Jay
Re: Keep Remote Directory up to Date - Startup script
I'm not sure I follow. Are you asking how to make sure the "Keep up to date" function reconnects and resumes after the server is restarted? And doesn't it? It should.
