strange behavior after detaching external monitor
bartek_zgo
I'm using winscp version 5.17.10. on Win 10. I'm using external monitor that is attached to my laptop. Each time I detach external monitor and attach it again I have interface issues. Sometimes file icons disappear, sometimes the column size is extreme big. On the attached image you can that the "Name" column is so big that the next one "Size" is invisible. I'm getting crazy with this issue as I detach monitor 2 times a day.
Re: strange behavior after detaching external monitor
Please post a screenshot of your Windows Display settings for both your monitors.
Also, can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
bartek
I think the problem may be connected to resolution issues. My laptop has higher res than external monitor. So it looks that after detaching monitor the interface is rescaled to laptop monitor. When I reattach monitor it is not scaled down so the width in pixels remains the same while resolution is smaller.
