Permission denied (A)bort, (R)etry, (S)kip, Ski(p) all: Abort
jayaganesan
Malaysia
I have the following error
Distribution/AXFILES/RX
Error moving file 'SOD_OPD05102634_20210322_670510.XML' to 'SOD_OPD05102634_20210322_670510.xmltmp'.
Permission denied.
Error code: 3
Error message from server (en): Permission denied
I need SKIP so the process can be continue
Below is the my command
"E:\APOMS_BAT\MY\CA\autosys\ftp\WinSCP.com" ^
  /command ^
    "open sftp://avon_dc_new:gjr3wpwk@*****/ -hostkey=""ssh-dss 1024 /A=""" ^
    "cd /Distribution/AXFILES/RX/" ^
    "option batch continue" ^
    "option confirm on" ^
    "mv SOD*.xmltmp<1H *.xmltmptmp" ^
    "mv SOD_*.xmltmptmp /Distribution/AXFILES/RXFiles/" ^
    "exit"
What should I consider to change on the above script? Please HELP
Reply with quote E-mail
jayaganesan
Malaysia
Command update
Batch file used as below
  /command ^
    "open sftp://avon_dc_new:gjr3wpwk/ -hostkey=""ssh-dss 1024 /A=""" ^
    "mv SOD*.xml>0K<5N *.xmltmp" ^
    "lcd E:\Agility\RX" ^
    "get SOD_*.xmltmp SOD_*.xml" ^
    "exit"
How to solve this. Please help ASAP
Re: Permission denied (A)bort, (R)etry, (S)kip, Ski(p) all: Abort
