downloading all files even with filemask
cndesu
cd /
get -delete Prep_Report_Log*.xlsx
get -delete Ext_Report_Log*.xlsx
get -filemask="Crush_Report_Log*.xlsx>=3D"
get -delete EOf_Report_Log*.xlsx
The above is my script. It downloads all files irrespective of my filemask. Any help? I need to download only the files from remote server in last three days. The remote fileserver has 15 days of files.
Re: downloading all files even with filemask
I do not understand your question. Which of your four get commands have the problem? Your only command that has -filemask switch is not even valid, it won't download anything. Maybe you wanted this?
get -filemask=">=3D" Crush_Report_Log*.xlsx
cndesu
Sorry I have to be more descriptive.
This is the script I have.
cd /
get -delete EOF_Report_Log*.xlsx
get -filemask="Crush_Report_Hourly*.xlsx>=3D"
get -delete Steam_and_Gas_Log*.xlsx
close
First three lines are working fine.
cd /
The problem is at fourth line
Based on the FAQ, it said "*>=3D" so used that principle. I will try this as you said.
get -filemask=">=3D" Crush_Report_Hourly*.xlsx
cndesu
As I said, this line pulling all files like others, filemask is not working. No difference between the above two lines.
OK, but can you name a file that it is downloading, but it should not? I cannot investigate 20 thousand lines of logs file. Normal-level log file would be enough for this purpose.
cndesu
I enclosing the screenshots of the batch file where it is asking to run the winscp script. I also enclosed the screenshot of the command prompt what I am getting. I have enclosed the list of files in the remote server in another post.
May be this helps. I have highlighted in the screenshots.
Description: Winscp script
Description: Batch file where it is calling winscp script file.
cndesu
Description: List of the files on the remote server.
Description: Command prompt responses.
I'm sorry, but I do not think that you have given me the information I have asked for. Can you give me a name of one example file that was downloaded, although you believe it should not have been downloaded.
cndesu
No file is downloaded which is not asked for. Sorry to say or ask, at the same time no file is downloaded which is asked for.
I have asked for last three days files. The files were formatted with a generic name, and yyyymmddhhmmss.xlsx. I like to pull/get last three days files based on the timestamp concept which you have defined. Let me know if the syntax is wrong, as I am not seeing any files. With wild character I am seeing all the files.
The script you have posted above downloads file by their modification timestamps. Now it seems that you want to download by timestamp in their file names. That's a different thing. Anyway, if you have resolved your problem, can you share your solution?
cndesu
The modifications I did was on the server. I changed get command to filename>3D as the syntax. Previously the uploader software at the remote server used to dump all the 10 days files (total to 120) at one time. Syntax >3D did not work as timestamp was on same day. So trying with filename format which did not work either. Now everyday the server has files from previous day. Now the file time stamps are different. So syntax >3D worked. I do not know why the filename syntax with timestamp and wild character did not work.
Thanks for help.
WinSCP does not have a syntax for time ranges based on file names.
But you can explicitly name set of days, like this (just an example, has to be adjusted for the real timestamp and name formats):
# today's files
get Crush_Report_Hourly%TIMESTAMP#yyyy-mm-dd%.xlsx
# yesterday's files
get Crush_Report_Hourly%TIMESTAMP-1D#yyyy-mm-dd%.xlsx
# day-before-yesterday's files
get Crush_Report_Hourly%TIMESTAMP-2D#yyyy-mm-dd%.xlsx
See https://winscp.net/eng/docs/scripting#timestamp
