Does version 5.7.7.0 support FTP explicit TLS?
Steve34
UK
Apologies if this is documented somewhere. In version 5.7.7.0 is the following supported:
winscp.com /command "open ftpes://ftp.myserver.co.uk|myusr:mypasswd@ftp.myserver.co.uk"
Re: Does version 5.7.7.0 support FTP explicit TLS?
You should not use 5.7.7. It's over 5 years old.
Anyway, 5.7.7 supports the FTP with an explicit TLS encryption. But it does not support the ftpes prefix. Instead, use ftp and add -explicit switch. See help open.
Steve34
UK
Thanks Martin, it worked
My SSIS package was developed with the latest version of WinSCP. But the server has 5.7.7. Do you think my SSIS c# code will work on the server?
    Protocol = Protocol.Ftp,
    HostName = (string)Dts.Variables["User::HostName"].Value,
    UserName = (string)Dts.Variables["User::UserName"].Value,
    Password = (string)Dts.Variables["User::Password"].Value,
    FtpSecure = FtpSecure.Explicit,
sessionOptions.AddRawSettings("AddressFamily", "1");
sessionOptions.AddRawSettings("MinTlsVersion", "12");
    session.ExecutablePath = (string)Dts.Variables["User::WinSCPexePath"].Value;
    // Connect
    session.Open(sessionOptions);
    // Upload files
    TransferOptions transferOptions = new TransferOptions();
    transferOptions.TransferMode = TransferMode.Binary;
    TransferOperationResult transferResult = session.PutFiles(
        (string)Dts.Variables["User::LocalFilePath"].Value + (string)Dts.Variables["User::LocalFileName"].Value,
         (string)Dts.Variables["User::RemoteDir"].Value,
         true, transferOptions);
    // Throw on any error
    transferResult.Check();
I'm not sure you can run compiled C# code against different version of the assembly. But I'm not SSIS expert. Shouldn't the WinSCP .NET assembly be part of your SSIS package? What does it even mean "the server has 5.7.7"? Are you referring to WinSCP or WinSCP .NET assembly? Aren't you relying on the installed version of WinSCP.exe? You should not. Deploy your own version with your SSIS package.
See https://winscp.net/eng/docs/library_ssis#using
