Creating a folder to download into
Shay_
As title says, is it possible to have the batch file create a folder and download files into it so I can have multiple backups?
Also is it possible to download into a compressed zip file?
Re: Creating a folder to download into
Create the folder in the batch file using mkdir command. And then execute WinSCP from the same batch file for the download.
Similarly, if you want to ZIP the downloaded files, execute the "zip" after WinSCP finishes with the download.
Shay_
Sorry, I'm really new to all this. Could I get an example with my batch code?
If I do zip files, I'm hoping it'll create a zip each time with a timestamp so they're easy to track.
@echo off
  /log="C:\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://stuff@stuff/ -hostkey="""" -rawsettings FSProtocol=2 ProxyPort=0" ^
    "cd /17539" ^
    "lcd C:\Backups" ^
    "get folder" ^
    "get folder" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Shay_
An example if I were to use the zip command. You said execute zip once the download finishes right? So would it be something like this?
@echo off
  /command ^
    "cd /17539" ^
    "lcd C:\Backups" ^
    "get folder" ^
    "get folder" ^
    "zip -r "backup-`date +%Y%m%d%H%M`.zip" "backup/"" ^
    "exit"
  echo Success
) else (
  echo Error
I saw the command in another thread, but I'm not sure if it's the exact one I need to use. Right now I just want to download two folders and zip them into the directory with a timestamp.
Shay_
@echo off
  /command ^
    "cd /17539" ^
    "lcd C:\Backups" ^
    "get folder" ^
    "get folder" ^
    "exit"
  echo Success
    "zip -r "backup.zip" "!/"" ^
    "set TIMESTAMP_FORMAT=yyyy-mm-dd
winscp.com /command "echo %%TIMESTAMP#%TIMESTAMP_FORMAT%%%" "exit""
) else (
  echo Error
Did I do this correctly?
No. That's not the code from the article, it should be like:
for /F "tokens=* USEBACKQ" %%F in (
    `winscp.com /command "echo %%TIMESTAMP#%TIMESTAMP_FORMAT%%%" "exit"`
) do set TIMESTAMP=%%F
zip -r "backup-%TIMESTAMP%.zip" C:\Backups
I do not know about the zip commandline syntax, that depends on what implementation of ZIP you have. And that's not a WinSCP question anyway.
