SFTP slow performance - intermittent issue
Srinivas.reddy.vignan
India
We are using the WINSCP for SFTP file transfer. SFTP command triggering from informatica application server.
Sometimes it is completing the 40 MB file transfer less than a minute. But sometimes it is taking couple of minutes to complete.
Our observation. When we see the below message "Increasing the send buffer value from current value to double, it will transfer the file less than a minute.
When no change in Increasing send buffer value . It is taking long time to transfer the files.
Please suggest us do we have any parameters to change in WINSCP/SFTP client.
Please find below log for reference.
• Tried to compare SFTP logs for good performance (26 secs) vs. poor performance (12 mins 30 secs). In both the cases file size remains same.
• During slow performance, I don’t see Increasing send buffer entries and ~7 mins between below two events (in attached file, refer log events between 2021-03-03 02:41:04.955 and 2021-03-03 02:53:30.483)
o Initially buffer size is set to 262144 and later it’s not increasing
. 2021-03-03 02:41:04.955 Send buffer: 262144
> 2021-03-03 02:41:07.784 Type: SSH_FXP_WRITE, Size: 32761, Number: 1798
. 2021-03-03 02:47:46.698 2560 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
• During good performance, I see entries with Increasing send buffer. Not really sure how this is controlled and whether this is cause for poor performance (in log file, refer log events between 2021-03-03 03:39:07.966 and 2021-03-03 03:39:30.203)
. 2021-03-03 03:39:07.966 Send buffer: 262144
o Later it’s increased to 2097152
> 2021-03-03 03:39:10.388 Type: SSH_FXP_WRITE, Size: 32761, Number: 1798
. 2021-03-03 03:39:11.325 Increasing send buffer from 262144 to 524288
. 2021-03-03 03:39:12.325 Increasing send buffer from 524288 to 1048576
. 2021-03-03 03:39:13.326 Increasing send buffer from 1048576 to 2097152
. 2021-03-03 03:39:18.827 2509 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Reply with quote E-mail
Re: SFTP slow performance - intermittent issue
The increase of the send buffer comes in a response to SIO_IDEAL_SEND_BACKLOG_QUERY:
https://learn.microsoft.com/en-us/windows/win32/winsock/sio-ideal-send-backlog-query
How that query determines, if the buffer should be increased, is out of WinSCP control.
Though you can fix the buffer to large initial value using SendBuf raw session settings:
https://winscp.net/eng/docs/rawsettings#sendbuf
Hi Martin,
Thanks for the update. We have tried to update the send Buffer value , SshSimple.
SendBuf Optimize connection buffer size 0 = Off, Any positive value = On, value indicates size of the buffer, with recommended value of 262144
The SshSimple may need to be set to 1 to disable some of the optimizations, that unchecking the GUI option disables.
We have updated the values as below But after saving these values are disappear automatically. It is not saving permanently. Could you please suggest to save the settings permanently
SendBuf=2097152
SshSimple=1
Regards,
Srinivas
I didn't ask you to set SshSimple. When exactly does the SendBuf disappear automatically? It does not disappear for me.
